04-16-2014 03:56 PM - last edited on 03-05-2024 10:24 PM by ROGBot
04-22-2014 07:41 AM
04-22-2014 11:55 AM
04-22-2014 05:30 PM
GoosNL wrote:
there are no updates yet, V1.00.10 is the last firmware
04-23-2014 10:57 PM
Necrosan wrote:
Visit here and select Win 8.1 64 bit and look under utilities: https://www.asus.com/Motherboards/ROG_Front_Base/HelpDesk_Download/
Here is a screenshot of said utility:
Was this released in error? Is this just the utility to update the firmware, and there are in fact no updates?
My unit has exhibited no problems; I just am curious as to what this is and why it's missing the actual firmware.
Thanks!
06-05-2014 05:06 AM
06-05-2014 07:03 AM
06-05-2014 10:41 AM
InToSSH wrote:
Hi, you can use this new driver V1.01.05 with firmware V40, provided by Raja@ASUS on the other thread: https://www.asuswebstorage.com/navigate/s/E12551DE5D834B59917C15349CEED8B14
It contains driver, flash utility, new FW and flash guide, it should be all you need to upgrade it.
this is the original thread: http://rog.asus.com/forum/showthread.php?47735-Problem-with-asus-front-bases-and-maximus-vii-hero-fi...
06-05-2014 10:22 PM
06-06-2014 03:09 AM
InToSSH wrote:
Did you connect the Front Base just to USB using Q-connector? Not directly to ROG_EXT header? This looks like its connected to ROG_EXT and its not recognized as "WonderBox" (I hope I remember it right). If its connected throught Q-connector, try different mobo USB header.
