Anyone having an issue with a AIO cooling unit and the Front Base? I'm running a Formula VII MB with a Thermaltake Water 3.0 Extreme Cooler. This cooler has the fans connect to a Y connection and then one connection to the MB. I have said connection plugged into the main CPU fan connection on the MB, and it's working correctly, but my Front Base reads 0000 RPM for the fan speed. On a cold start, I'm also getting a POST error saying there is a problem with the CPU Fan (One long beep, followed by 4 additional short beeps), that only occurs on a cold start, not a shut down restart.
PC has been running fine for two days with temps in the low to mid 30's.
