Hi guys,
I'm starting to get really angry an the AI Suite
😄It is giving me trouble controlling my CPU Fan. Specifically the Arctic Freezer 13 Pro.
Let me explain the stupid CPU cooler first:
It has two fans. A 120mm PWM and a 50mm "Crossblow" , which Arctic claims is PWM as well (700-2700 rpm), but looking at the cables there are only three wires to the 50mm and the yellow one goes through to the 120mm. So I guess the 50mm is a 3-pin fan. Both are connected together.
Since it is on the bottom of the heatsink I never watched it before, so I can't tell if it spins fast/slow or at a constant speed.
Till now I hat them run together like they came out of the box and had no problems with it. So I didn't care.
On my previous board (P5Q Turbo) I was using PC Probe II, which worked flawlessly.
Now with my Maximus VI Hero and the ROG AI Suite 3 it doesn't work anymore.
I tried different configurations:
- Fans together like stock, no calibration in FX2 = worked like a charm
But I want to make use of the Software's capabilities, so I ran the calibration. That's when the probs started...
The CPU Fans wasn't recognized at all as it was. I figured it was because of the 3-pin / 4-pin connection the heatsink has, so I ordered a PWM extension and disconnected the fans. Now the 120mm and 50mm are on their own.
- 120mm PWM @ CPU_FAN = runs full speed
- 50 mm @ CHA_FAN = not detected, grey exclamation mark, spins at full speed as well. No BIOS detection.
- 50mm @ CPU_FAN = no detection, F1 No CPU Fan Error, runs full speed
- 120mm @ CHA_FAN = works
So I disabled the No CPU Fan warning for the time being and monitored it.
I don't like this config. Makes me feel uncomfortable that there is "no CPU Fan" installed, in case something goes wrong...
After an hour or so the 50mm Fan began to make scratchy noises. At first I thought a cable got in the way. I checked and nothing. It just makes noise. I think, cause FX2 couldn't control the 50mm fan, running at full speed damaged the bearings of the fan. So that's nice...
😞For now I unplugged it. The MoBo temps got 3-4 deg higher (38°) ... so yeah, it sucks.
Anyway, i switched the 120mm back @ CPU_FAN, where it runs at full speed and is not recognized by FX2, so not controllable.
AFAIK CPU_FAN connectors work with PWM and CHA_FAN connectors with both. That didn't seem to be the case.
My 50mm 3-Pin didn't work on either connectors and the 4-Pin PWM CPU Fan doesn't work on the CPU_FAN connector.
Befor the calibration they worked. Together and separately. So the Fans or the MoBo are not the issue. The Software is.
Now I'm thinking of uninstalling that crappy AI Suite 3 and try the "full version" of Fan Xpert2 (link?). Maybe that works.
Although i would prefer if it works with the AI Suite 3, 'cause I like all the other monitoring features.
Ideas anyone?!
= Maximus VI Hero - i7 4770K - G.Skill 32GB Ram - Corsair 900D - Custom WC loop =
