12-02-2012
05:20 PM
- last edited on
03-06-2024
06:40 PM
by
ROGBot
12-04-2012 01:36 AM
12-03-2012 10:12 AM
12-03-2012 02:27 PM
X Pack wrote:
Are you trying to pwm control the chassie fans? or the opt fans?
it would be way more easy if you told us
Take the pwm signal from the cpu_fan header..
Or get a pwm fan controller?
You cant use the opt and chassie fans as cpu_fan, and want them to adjust after cpu temp..
You can connect a temp prob to one of the opt fan header, and having that header temp controlled.. Stick the probe into the rad or something
pwr_fan> constant 12v feed
Cpu_ fan> cpu temp controlled
Opt-cpufan> optional cpu fan, it tag along with cpu_fan
Chassi fan> For using chassi fans, can be duty controlled and via profiles
Opt fans> Optional fans, can be used everywhere, and for having them adjust to the temp, you need a temp probe. else they can be adjusted via duty, and profiles also
i told you this already?
Or get a pwm fan controller....
12-03-2012 10:48 AM
