What is your duty settings in bios> Fan speed?
opt_1
opt_2
opt_3
chassi_fan (which profile are you using)..
q Fan enabled?
The cpu_fan and the opt_cpu fan. adjust after the cpu temp..
Chassie_fan.. Is chassie fan plain and simple, you can set them as you want, using manual, or profiles.. they cant be controlled individually..
Opt_fan1,2,3 is controlled via temp probes, (manual mode), or else you can set the duty/profile in bios..
the opt_fans (not cpu_opt fan), can be controlled individually.. ex.. opt1 run at 40%,..opt2 controlled via probe (manual profile).....opt3 60%
or how you prefer..
PCH Fan is also controlled in there, you can set profile, or set one manual..
Its simple..
haha, would you not have been frustrated if it had coast 215 usd?
I dont understand..
Bios> Fan speed control or monitor... dont remember..
