12-01-2013 08:19 AM - last edited on 03-06-2024 06:45 PM by ROGBot
12-01-2013 08:28 AM
12-01-2013 08:33 AM
12-01-2013 08:43 AM
12-01-2013 08:57 AM
12-01-2013 09:20 AM
12-01-2013 10:12 AM
12-01-2013 10:48 AM
12-01-2013 10:53 AM
HiVizMan wrote:
Yes I was sure it would boot in the furtherest slot. Which is why I told you to do that. 🙂
Your system is trying to find the boot MBR with AE and it is not finding it hence the q-code you got.
Check that your keyboard is being picked up, and if not change the USB port used. Press the del key on your keypad to get to bios. Or failing that pull your CPU fan header during the post process and you will get a CPU fan error. Stick the fan on the CPU OPT header for now. F1 to get into bios.
12-02-2013 04:28 AM
