01-06-2016 05:24 AM - last edited 3 weeks ago by ROGBot
01-06-2016 05:38 AM
allocen wrote:
So, i have this problem like recently i decided to upgrade my 16 gb ram to 32 gb ram. The ram i use are called HyperX Beast at Freq of 2400mhz. The motherboard is Maximus VII Formula and the CPU Cooler is a Noctua DH14, the first two slots of ram are occupied by these HyperX Beast ram. My question is if on the latest 2 slots from the right that goes right under the Noctua's Fan will fit another two HyperX Beast ram? I need a 101% honest answer... . Someone recomanned me to go after HyperX Savage which seems to be a little smaller in height than HyperX Beast. The problem is if i buy those and put on the latest 2 slots on the right (hopefully will fit) will be there a problem? I have to take the HyperX Beast ram from 2nd slot and put it on the 3rd one? Does the ram position slots matter on this motherboard? I just need some honest answers on this, like which ram will fit on the latest 2 slots of ram under the Noctua's fan and if the ram slot position matters.
Thank you, Daniel.
01-06-2016 05:47 AM
allocen wrote:
So i guess, putting my two HyperX Beast on the very two slots of ram was not good, wasn't it?
01-06-2016 05:46 AM
01-06-2016 06:00 AM
allocen wrote:
Well, it seems that HyperX Savage will fit. But now the bigger problem is that i have to take out the HyperX Beast from A2 and move to B1 so i can put the Savage to A2 B2, which B1 is right under the Noctua's fan...and HyperX Beast wont fit. What can i do? 😞
01-06-2016 06:15 AM
01-06-2016 05:52 AM
allocen wrote:
I see, and what about the latest post...?
