q-code 62 and VGA led
ivanac
hi, just sry at first for my bad english
i ve built this pc 1 week ago, all seem like to was fine till the vga (gf 770) begin to have some crash, or i think was that. actuallythe pc is crashed. in a first time the q-code 62 and boot led came on.
i ve reseted bios by battery with naked MB then reassembled all the things( cpu, mem, hdd and opt. disk) not the vga.
now i still have the q-code 62 but with vga led, vga on or not.
pls help me ^^
29 REPLIES 29
ivanac
now i ve to go at work, i can read any replay this evening only, thx
Arne_Saknussemm
Level 40
Hi ivanac :)....can you confirm the code is 62 or b2?
Can you also tell us your hardware exactly. What RAM etc.
Have you cleared CMOS? tried with only one stick of RAM in recommended slot...?
HiVizMan
Level 40
Please list all your hardware and it will be easier to help you.
here i am back from work.
ofc, Motherboard MAXIMUS V FORMULA
i5-3570K 3,40 Ghz HD 4000
coolermaster Blizzard T2 cpu cooler
Dimm Vengeance 16GB (2x8GB) DDR3 1600 MHz CL9
GeForce GTX 770 2 GB
DRW-24F1ST DVD 24x
well, at this time i've already tried bios reset in the reccomended way 2 times, without results; then tried cmos clear.
the q-code 62 (not b2) with vga led on, still there, even if the vga wasn't connected (monitor conn. to mb).
DRW-24F1ST DVD 24x
Arne_Saknussemm
Level 40
Hmm.....Have you tried switching the GPU to another slot....do you have another GPU to try in the board? Have you tried only one stick of RAM?
You have reseated the power connections to the GPU?
Are you on the latest BIOS for that board?
ivanac
yes on all. 2 days ago i update bios to last version 180..forgot final, tried the gpu slot change, tried with another gpu ( an old serie gf 9600) ^^
tried with 1 dram.
ivanac
good night everybody, cy tomorrow:)
ivanac
hello everybody, are there any body out there? 😄
anyway, this morning i tried to check the sistem by ROG connect and it say that its locked with indications about cod 62 and the suggestion to check cpu. is there the possibility of the cpu brock or something like that?
MB still light the VGA led with q-code 62.
CORSAIR Vengeance 16GB (2x8GB) DDR3 1600 MHz CL9
DRW-24F1ST DVD 24x
