I had a working rig for 1+ years when I starting have issues with my Corsair H100 water cooler. I had to RMA that device, and received a new H100i water cooler. I never de-connected/de-seated the CPU, only removing the water block/pump itself and replacing with the new version. The standoff's and backplate was identical for both models.
After re-assembly today, I see the Q-Code run the diagnostics and show a error 56 for a second, then sit on 55. Additionally the DRAM LED is lit red on the board as well. New Cooler is working properly (working LED's on cooler) and radiator fans and all case fans and lighting are running normally.
::Steps taken::
Loosed water block to ensure no MB warping
Removed all RAM (4x8) re-seated.
Single DIMM in A2 | Error 55
Pressed "Go Mode" | Error 55
Held dowon "Go Mode" for overclocker profile? | Error 55
Moved 2 DIMM's to B1 & B2 |
Success!Swapped 2 good DIMMS for A1 & A2 | Error 55
Loosed H100i, Single DIMM in A2 |
Success!All 4 DIMM's with hand tight H100i | Error 55
A2 + B1 & B2 populated |
Success!Tighten down H100i with screw driver to very light pressure |
Success!::Result::
I have a working machine now minus 8 GB RAM with a bad A1 slot in my MB. Mem Tweak report for my current system
here.
What are the next steps I can take to try and get my A1 slot working and get my other 8GB of memory back?
I'm currently running BIOS version 0257 x64, is there a new firmware I should try?
Is this something that can even be fixed with software?
Thanks for your help.
John
