Problems with X870e Hero motherboard and EXPO profiles
CptMario
Hi! I made a video of the problem im experiencing and a temporary fix. Maybe someone will find this post useful,  I hope someone from ASUS sees this and updates the BIOS with these fixes or provides some technical support in the comments below. Its very frustrating dealing with this and this is not the first time im having issues with asus motherboards. Thank you, please watch the video.   https://youtu.be/H8FdNK10H2w?feature=shared
My PC:
Ryzen 9 7950x3d
X870e hero
64 gb  ram - G. Skill Trident Z5 Neo 2x32 GB Model: F5-6000J3040G32GX2-TZ5N
RTX 4080 super Suprim X
x2 NVME ssd 990pro 1 tb and 4 tb both working fine
Win 11 64bit pro
9800X3D / RTX 5090 / X870e Hero / 64 GB DDR5 @ 6000 MHz ~ Expo Tweaked
206 REPLIES 206
Instead of putting the second stick, replace the first stick that works with the second.
Boot with this second stick and wait for it to boot with EXPO. If it starts, turn off your PC, put the 1st stick back in slot 1 (A2) and the second in slot 2 (B2) (they are numbers behind so as not to confuse them)
This is what allowed me to “train” the sticks one by one.
Be careful to insert the sticks in A2 and B2. We can quickly make a mistake.
It takes a maximum of 60 seconds for a stick to pass the test the first time it is trained.
My theory is that only port A2 can drive the memory, and therefore it must be done stick by stick on this connector only.
I know it's a bit of a stupid solution but I'm convinced that the problem comes from the way the memory is trained and the port used. It's like buying 4 tires that only work on one wheel and having to mount each tire on the same wheel one by one to test the rolling. Courage to you guys.
My second theory would be that the motherboard drives stick1 which would be better than 2 at frequencies too high for the 2nd. This causes a bug when the 2nd is connected to B2 because it is not capable of maintaining the frequency of the 1st.
I did this, booted with one stick expo at 6000 no issues. When the second stick is in, it will not boot past bios, it's like it can't fully apply expo anymore with both sticks in...
What is your serial number KIT ?
MY MOTHERBOARD : ProArt X870E
BIOS : 0706
RAM : CORSAIR 2x32gb - 6000Mhz - CL30 - ref.: CMH32GX5M2B6000Z30K
PROCESSOR : Ryzen 9600X
If both sticks manage to launch at 6000 MHz with EXPO I or II, it's too strange that the motherboard does not boot with both.
Do you have the possibility to test with other KITs? (or other processor ?)
MOTHERBOARD : X870E Hero
BIOS : 0606
RAM : G.Skill Trident Z5 Neo RGB 2x16GB DDR5 6000MHz CL30 / F5-6000J3038F16GX2-TZ5NR
PROCESSOR : Ryzen 9800X3D
Any expo setting with both sticks will turn my pc off and back on and get me to this. It worked before with no issues but for the past 2 weeks now got bsods and crashes to the point i cant even boot at all now if i am not at stock speeds. Got a new ram kit on the way, same one...will test with that
neopassive
I'm fairly disappointed this hasn't been issued an actual fix or official response. I'm approaching the end of the return window for this MoBo, and this issue has me on the fence for returning or not. I'd like to maintain optimism that there will be an update to fix this. Unfortunately, it has been going on for a while with a variety of threads on the internet saying the same thing. I can not help but wonder if the board is a lemon or has an inherent defect that can not be patched. It would be helpful if there were any official responses as to what may be expected going forwards so I can make an informed decision for what to do with the board.
NomadG19
Ok so I Bought my new pc at Microcenter on the 11th. 4 ENTIRE rebuilds,  100% all NEW parts each time.  NEW cpu, ram, ssd, psu, gpu.
ASUS ROG X870e crosshair hero Board. G.SKill Trident Z 6000mhz cl30 RAM, QVL listed. 2 sticks at 16gb.
OCCTA core errors all over using expo 1 or expo 2.
Please asus! I paid 670 USD for this Board.  Make it STABLE!
cutedaniel88
So I'm not sure if this will help anyone, but I ran into the same problem, but resolved it. In my case, it seems if you plug in your ram into the wrong memory slot order it will cause this problem.
I'm my example, I have 3 sticks of ram, which is weird I know, the 4th was faulty.. anyway, I originally used slots 1/2/3, and could not get it to post on a profile however it worked fine in default. Looking in the manual, on the second bank, slot 4 is listed as #1 for that bank, so using slots 1/2/4 worked fine. That being said the tweaked profile did not work but the others did fine.
Although I highly doubt anyone else is using 3 sticks of ram like I am, it may be worth ensuring that you are using the correct slot order. It could probably also be affected by using bank b instead of bank a first if you are only using 2 sticks.
Just something to keep in mind. Cheers.
ComputerManBG
Hello, today I updated the computer with...
Motherboard: Asus X870E Hero
Processor: AMD 9800x3D
Memory: DDR5 2x32(64Gb) 6000Ghz CL30 Dominator
Cooler: Asus Ryujin III 360.
After I assembled it and turned it on, everything started, fans, lighting, the pump is audible but no picture. The motherboard displays code 15 preceded by a yellow "lamp" and after a minute or two the code becomes 46 with a red "lamp" and sits like that. It does not boot to either the bios or the window.  I clarify that this is not the first computer I have assembled, I am aware of the matter.
Things I have tried so far.
1: I have checked every cable, connector and so on to see if it is connected correctly and where it should be.
2: I downloaded the latest not beta BIOS for the motherboard from the Asus website and flashed it to the latest version using the Flashback option on the motherboard. At least according to the indicator that blinks during the process, the flash was successful. I can't enter the BIOS so I can't say it's 100 percent.
3: I did Clear cmos several times, waited for 10, 15 minutes followed by a restart on my part, with no result.
4: I tested each RAM stick separately in each of the four slots, the result and codes were the same. I tried without any RAM (I know it won't boot), the code it displays is 10.
5. Starting the computer without any cables plugged in (except the power cables for the processor and motherboard), fans, RGB, etc. The result is the same, a minute of code 15 and then code 46 and that's it.
6 . Starting the computer with the video card and Nvme drives removed (which I have tested in three different slots. The result is the same. I specify that I am sure of the drives (two in number) and the video (4090 strix), I have no problem with them. They have been used until yesterday from the old configuration together with the power supply and have always worked without problems. The same applies to the power supply (Asus 1200W Thor Platinum).
7 . New flash of the bios with the latest beta update. The result is the same.
8.  We reach the point from which I personally think that there was no point.. Removing the processor.
The socket and the pins are completely okay. I even remove the holder to see and inspect it better. From the inspection, I don't see any problem with the socket. The processor from the bottom looks completely normal. I don't see any marks or burns.
I should add that I tried to start without a processor but the computer wouldn't start. The same was true of the old STRIX X570 E motherboard. It starts without memory and sits at code 10 and that's it.
I put it back together, connected everything and the result is code 46. I'll wait until the memory arrives and see if it's from it. Expensive is definitely not always the best. Once again I'm convinced of this.
Personally, I doubt it's from the RAM, some incompatibility or bad memory. My previous motherboard also had some kind of memory problem from time to time, apparently this is AMD's weakness. I ordered two new 32Gb sticks of Vengeance 6000Ghz. As far as I know, they should work most stably at this purity. If anyone has an idea that I can try while I wait for the memory to arrive, I'd be happy to hear it.
Hi @ComputerManBG
1. Update to new AMD AGESA on UEFI 1002, see if this helps.
2. Reseat CPU. Ensure the CPU pin pad and socket have no damage or debris. Reseat cooler and CPU whilst ensuring for even mounting pressure as per cooling vendors instructions.
3. If using a CPU contact frame, remove it and return to the stock retention mechanism.
The problem is that I can't enter the BIOS or Windows.
I don't know if they can be updated via flashback
As I said in the first post, I removed the processor and checked the socket and pins, everything is fine. I'm sure the cooler is installed correctly.
I don't use a CPU contact frame
