Problems with X870e Hero motherboard and EXPO profiles
CptMario
Hi! I made a video of the problem im experiencing and a temporary fix. Maybe someone will find this post useful,  I hope someone from ASUS sees this and updates the BIOS with these fixes or provides some technical support in the comments below. Its very frustrating dealing with this and this is not the first time im having issues with asus motherboards. Thank you, please watch the video.   https://youtu.be/H8FdNK10H2w?feature=shared
My PC:
Ryzen 9 7950x3d
X870e hero
64 gb  ram - G. Skill Trident Z5 Neo 2x32 GB Model: F5-6000J3040G32GX2-TZ5N
RTX 4080 super Suprim X
x2 NVME ssd 990pro 1 tb and 4 tb both working fine
Win 11 64bit pro
9800X3D / RTX 5090 / X870e Hero / 64 GB DDR5 @ 6000 MHz ~ Expo Tweaked
206 REPLIES 206
Couldn't you just set the timing manually matching expo?
I guess I could. But this got me up and gaming. I’ll have to try it later.
_JFK_
Manually entering the timings doesn’t seem to matter. 🤷‍♂️ Just fails with 4 sticks on Expo or manually entered timing. 2 sticks work fine with Expo.
Did you try switching the other sticks to make it's not a problem with the ram? Also did you OP suggestion?
I have tried swapping kits, slots, and it’s the same.
by OPs suggestion, do you mean enabling Memory Context Restore? If so, I haven’t, but I’ll give it a try.
Also, I have a Corsair t705 in m.2 slot 1, and my other (t705) m.2 in slot 5 as I was not wanting to mess with slots 2 or 3. They appear every time and don’t seem to have any issues.
mrdagger
Same Issue:  9800X3D, 870e-e and 64 gb  ram - G. Skill Trident Z5 Neo 2x32 GB Model: F5-6000J3040G32GX2-TZ5NR memory.  Should I just wait for Asus to release a working BIOS?  Can't get computer to boot with any type of memory adjustment.  Hoping to see an alert for a new BIOS with this issue fixed 🙂
Guys. To get stuff to boot just without expo just with manual just set the cpU VDDIO/MC voltage to manual and then override to 1.396. You can’t set expo, but it will work for manual and it won’t be perfect. You won’t pass memory test, but you can play games until Asus fixes this nonsense.
_JFK_
Just to clarify, I’m trying to use 2 sets of F5-6000J2836G16GX2-TR5NS. Again, which is on the qvl.
You can't combine kits. Please read here: https://rog-forum.asus.com/t5/technologies-explained/memory-kits-overclocking-and-what-you-may-not-k...
Gotcha! Thanks!
