Problems with Asus Crosshair V Formula Z
Bertizone
I I run Crossfire system with two HD 7950er cards Bring this as a single in Heaven 4.0 with Extreme 1115 points in the OC. But when Crossfire the same value or even a two more points.
I have already spoken with Asus Did the first time bios update that is Down until a few days ago and the power supply must ie votes The 4 pin molex on the board to be Connected yes he was.
I then times just so the 4 pin Molex Omitted and you can see that there is no change.
Do you have a tip?
madcratebuilder
Have you disabled ULPS in the registry?
Speedbird 9590@5.1/CHVFZ/8gb G Skill@2133/ASUS R9-280X all on EK blocks controlled with Aquaero 6 Pro
Goonybird 8350@4.6/GA990FXAUD3/16gb Corsair@1600/Crossfired Sapphire 7990's cooled with CM 240L XSPC res
