Problem with ROG Strix B650e-e DOCP RAM Problem
Stolleflitzer
Hi ! I run a System with Ryzen 7800 X3D and ROG Strix B650e-e. When i enable any of the 2 availble DOCP profil's i get a Blackscreen and the PC w'ont boot. My RAM is a Corsair Dominator Platinum CMT32GX5M2B6400C32 (2 *16). On the Supportsite it says that this Kit is supportet.Typing in the needet Values (CL's & Voltage usw.) manuly does not fix it and lowering the MHz at 6200 or 6000 also does nothing.
I tryed another Kit (also allegedly suported) and get the same Problem. The 2 Sticks are placed in the correct Slots (checked user maual).The Bios is updatet to the newest version.
Has someone any idas how to fix this ?
5 REPLIES 5
MrAgapiGC
Level 17
I can not find that ram on the database
I do recommend ALWAYS to use expo ram for AMD and up  to 6000mhz
There are others and they are NOT the same as yours.
Learn, Play Enjoy! We help and collaborate, NOT complain!
Stolleflitzer
There it is on the bottom
Silent_Scone
Super Moderator
Hi @Stolleflitzer
1. Set DOCP 2
2. Lower DRAM Frequency to 6000MT
3. Set VSOC to 1.3v and VVDIO to 1.45v
4. If no change, reseat the CPU - ensure for consistent cooler mounting pressure.
Stolleflitzer
Sadly stil Blackscreen after the Settingchange. Thx for the Answers from both of you btw.
Check CPU mount. Can impact OC.
