Problem build
allocen
So i have a MAXIMUS VII Formula, i want to upgrade the psu from Corsair 750 to Seasonic x-series 1250w. At the same time i plan to make a sli with 980ti. I also have Zalman Z-11 h1f1 plus case. Will everything be ok? No problem with fitting or small psu or something?
4 REPLIES 4
allocen
My full pc specs are:
Motherboard: Maximus VII Formula
Processor: Intel i7 4790K
Cooler: Noctua D14
Ram: 2x HyperX Beast 2400mhz 16GB
HDD: 1B WD Blue
SSD: 1x Samsung Pro 128gb, 1x Samsung Evo 250gb
Gpu: Msi R9 280 Direct CUII
Psu: Corsair 750
Case: Zalman z11 H1F1 Plus
Nate152
Hello allocen
I don't see any problems running 2 gpu's as it supports full size gpu's and has 7 expansion slots.
Everything should fit just fine.
allocen
So about the speed of Pci Express slot, first one is about 16x, and the 2n one is 8x, is there a problem on this motherboard..or?
Nate152
No it's normal for the pcie lanes to run at x8 with two gpu's as the 4790k only has 16 lanes.
Don't worry performance is negligible going from x16 to x8.
Everything looks good so far I'm going to check the height of cpu coolers your case supports.
If you already have the nh-d14 installed then there is no need for me to check. 🙂
