Power connection on the Maximus VI Formula
rolldog
I'm trying to finish up my build, and I have a question. I'm running the Asus Maximus VI Formula motherboard and I'm using a Corsair ax1200i modular power supply. Do I need to plug in the 24 pin power adapter, the 8 pin power adapter, and the 4 pin power adapter? The manual was kind of confusing saying if I could plug in the entire 24 pin adapter, then I wouldn't need to plug in one, or both, of the 4 pin and 8 pin power adapters. The manual showed different scenarios with different connections, but to me it came across as if you have the full 24 pin adapter, which plugs in next to all the SATA connectors on the right side when looking at it installed in the case, then you might not need the 8 pin and/or the 4 pin power adapter. I just want to make sure before I turn it on. Thanks.
4 REPLIES 4
kkn
Level 14
24 + 8 HAVE to be connected.
the 4pin is for high OC, but wont be wrong to connect it if you want to, and connect the molex cable too.
The molex at the bottom of the board? On the row with the USB 2.0 pins?
abvolt
Level 11
That molex is for extra power to the vga's I always plug it in..
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
Yea, my 780ti probably needs more power than the other 2 power adapters plugged into it. Thanks a lot for the info. I really appreciate it.
