Please help 92 hang
asheen
I have a p8z68, 2600 (non-k), 60gb OCZ SSD, 8gb mushkin blackline ram, 2x 760 MSI.
Currently I am getting a system hang at 92 q-code. Everything is getting power, and when my monitor kicks in, the DVI logo for input is displayed, then the whole thing goes blank. No boot menu, no logo, no windows, no image at all.
Can anyone tell me what is going on? I have windows 7, i actively update, keep my computer clean of virus and malware. I have swapped video card PCI slots, ive removed one card and kept in pci 1, nothing, moved that same card to pci 2, nothing. Exchanged for my 2nd video card, and same results. I've done RAM checks as best as possible, and it doesn't seem to be an issue there.
Did my mobo crap out? HELP!
6 REPLIES 6
HiVizMan
Level 40
Please try this.
Remove all USB devices, and the SATA devices (make sure you know what your OS drive is and leave that one in.)
Now remove all but one stick of memory and pull the SLi bridge from your 2nd graphic card.
Boot up and if successful start adding one item of hardware per boot to OS.
Ive done the sli bridge and ram. Ive even removed both cards, put each in pci 1 & 2, nothing. Best ive come so far is CMOS reset, actually brings up a display, but I cant do anything from that point.
asheen
UPDATE: Resetting CMOS brings up the asus logo screen, but I hit DEL to enter bios menu and nothing happens. Ive tried usb and ps2 connected keyboards, no change.
asheen
UPDATE 2: I HAD TO LITERALLY UNPLUG EVERYTHING. works now, dont understand why it wasn't posting properly.\
HiVizMan
Level 40
Wonder if you had a temp short in your case??
MeanMachine
Hi asheen.
If its hanging on Qcode 92, Its trying to initialize the PCI bus and can't.
Do you have any risers (any other cards in) and if so are they well seated?.
You may have to Bench test outside the case and test your PSU.
If still no go, RMA the MB.
Ah I see you are up and running.
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
