PC won't power on after shutdown
Digitalle
4670k
Asus Gene VI
Seasonic G 550W Gold
HD 7970Ghz
I was playing about with my overclock last, as I tend to do, and I think I may have pushed it a little far on the v-core. I've had it stable at 4.2 @ 1.3v (I know it got an absolute terrible chip) for a year-ish now and thought I'd try get just a little more out it, in preparation for my new 970's coming today. Think i had bumped it up to 1.32 to try and get 4.3/4.4.
Saved the setting and restart and it just didn't boot. all the power LED's are on on the mobo but no reaction from the chassis power button/the start button on the mobo itself. The only way I can get it to boot is by removing the power cord and leaving it for 10 minutes, it will then start up fine first time, but after one shutdown the same issue. No boot.
What have I fried?
I had also just installed and upgraded the firmware on my H100i, the only other recent change at the time.
7 REPLIES 7
Nate152
Hello Digitalle
Your psu could be the problem.
If you need 1.30v for 4.2Ghz, you're gonna need more than 1.32v for 4.3/4.4.
Try clearing the cmos or resetting the bios to defaults.
Do things go back to normal?
Digitalle
Hello
Yes clearing the CMOS was the first thing I tried, first by using the 'Clear CMOS' button on the rear I/O, then by removing the battery for half an hour or so. It then prompts the 'press F1' to setup on start up, which is fine, but then once I try to shutdown/restart from there the same problem occurs. No response from either the case power button or the power button on the motherboard itself.
Nate152
I should have noted 1.32v is not too much if you have adequate cooling.
Since clearing the cmos didn't help, I'm thinking it's your psu.
Would you have another one to test with?
Digitalle
I don't, I have a mulitmeter though so I can do it manually.
Mike724
We invite you to explore our site to learn more about who we are, what we do and how we can assist you and your loved ones. You will find a wealth of valuable information here, including videos and blog posts about topics that, over the years, many of our clients have asked about at our initial meetings. You can also read testimonials from satisfied clients, learn about upcoming events and request a copy of our informative and fun newsletter.
living trust attorney california
assetprotection
kkn
Level 14
^^ spam and dont click.
Hyper_Droid
Messages like those should simply be deleted by staff...
Maximus VI Formula I Intel I7 4770K I Corsair Vengeance 16Gb @1600Mhz I 240 GB Corsair Force GS Series SSD I WD Caviar Black 2TB I Corsair H100i I Seasonic 1250w I Corsair Obsidian 800D I 2x Sapphire R9 290s (2x4GB) in Crossfire I 3x BenQ 2450hm 24" in Eyefinity I Razer Chimaera Headset I Mad Catz Cyborg R.A.T. Mouse I Corsair K70 Mechanical Keyboard
Youtube: HyperDroids // Instagram: @latesttech4all
