10-23-2022
05:04 PM
- last edited on
03-05-2024
12:24 AM
by
ROGBot
10-28-2022 10:24 AM
11-02-2022 08:14 AM
11-14-2022 03:04 AM
07-02-2023 09:14 AM
Sadly, I replaced the bios battery with a new one and still have exactly the same problem.
07-05-2023 10:28 PM
Solution / Workaround #1
Solution / Workaround #2
The problematic area, in my opinion, may be linked to the Asus Profile Tool which allows you to save and load UEFI BIOS configuration settings.
I Hope this Helps Others
Regards,
Mike
07-06-2023 02:55 PM
Unfortunately I cannot make changes in the BIOS. It is one of those old useless BIOS menus with the blue header and white background. There are no options to change the CPU overclocking in the BIOS. It has to be done with the Asus ROG Gaming software.
