Overclocking help
LethalSealzz
have a M5A78L-M LX motherboard AMD 4100 and OS 8 but when i go to download turbo key off the utilities disc it says not compatible does anyone know a way i can overclock my computer?
Granger
The best way is using the Bios, software for overclocking isn't that great 😉
Zka17
Level 16
I agree, if you want to OC, then do it from BIOS - manually... You can find very nice guides on this Forum about OC'ing, and who knows... you may actually like it! 🙂
WeRNothiNg
Overclocking with software always causes my system to function less efficiently. more lag in games and so on. BIOS is the only way to go. Turbo key can also cause your system to be more unstable than some of the other OC software I've used.
**i7 3770k @ 4.5GHz~ Cooler Master V8 ~ Asus Maximus V Formula ~ G Skill Sniper Gaming Series 16GB DDR3-1600 ~ Thermaltake Black Widow 850W 80+ Bronze ~ Kingston HyperX 3K 120G SSD ~ 2x WD Caviar Black 1TB
~ WD 500GB ~ 2x ASUS GeForce GTX 660 Ti TOP 2GB ~ Philips 1080p 39"**
[IMG][/IMG]
