Overclocking help needed
Crobar
I have 2133 Patriot Viper RAM and my Asus Crosshair V Formula runs it automatically at 1600. When I enter the bios and set it to anything above it causes windows 8 to crash and gives me the "blue screen"! Where can I secure detailed instructions on overclocking my ram, etc for my particular setup? Thanks for any help - My build is below.
AMD FX-8350 (OC to 4.5 currently)
Radeon 7970 with 3gb RAM (OC some)
32gb Patriot Viper 2133 RAM
Corsair Obsidian 650D Case
Corsair Hydro Series H100i liquid cooling
Raidmax RX-1200AE Power Supply
2 - OCZ Vertex 4, 256gb SSD Drives
1 - WD 1tb 7200 rpm HDD
2 - HP DVD
1 - LG Blu-Ray
4 REPLIES 4
Chino
Level 15
Welcome to the ROG forums, Crobar.
There is a short guide in my signature that might be of use to you. In your case, you wouldn't see the X.M.P. option but instead you'll have the D.O.C.P. option.
Would I be better served by changing my Mobo to the newer Asus Crosshair V Formula-Z rather t5han my current Asus Crosshair Formula?
Zka17
Level 16
Not sure if upgrading to the CHVF-Z will save you the time for memory tweaking... - have you checked CHino's guide yet? Or there is a CHVF OCing guide in the Crosshair mobo section too...
32GB of memory is a large amount to handle it... - is it a single kit or you mixed two kits? You could try removing half of the modules and see if it's working...
