03-22-2021 12:38 AM
03-22-2021 12:49 AM
03-22-2021 12:53 AM
Silent Scone@ROG wrote:
Hello,
Overclocking on this platform is quite limited. Enable DOCP and PBO and use the system as you intended. You can experiment with curve optimiser which can be found under the AMD Overclocking menu. Aim for a negative value to reduce voltage.
03-22-2021 01:47 AM
isaactwn wrote:
Thank you for your reply.
Yes, I did enable DOCP to overclock my RAM from C16-3600 to C16-4000, and enable PBO and curve optimizer. I left everything else to Auto and it gives me pretty stable performance.
I did try to tweak different setting manually but the system is not stable either under all-core or single-core OC though.
Thanks,
GTDragon
05-20-2021 12:28 PM
isaactwn wrote:
Thanks,
GTDragon
