Offset
andrea89
Ciao ragazzi
mi servirebbe un aiutino su come impostare l'offset...
io per il momento sto a 4.7ghz 1.355V...e possibile avere in offset questo V-core?in idle basso,e in full a 1.355v
Mi servirebbe impostare l'offset perchè almeno quando non gioco mi ritrovo il voltaggio molto basso e così anche le temperature, visto che qui ci sono quasi 40 gradi
Grazie
PS
faccio i complimenti ad ASUS per questa fantastica scheda madre!!! i love you
Hello boys
I could use a little help on how to set the offset ...
for now I'm at 4.7ghz 1.355V ... and this can be offset V-core? low idle, and 1.355v at full
I would set the offset game because at least when I find the very low voltage and so are the temperatures, because here we are almost 40 degrees
thanks
PS
I congratulate you for this fantastic motherboard for ASUS! i love you
CASE: Obsidian 800d MB: Rampage IV Extreme Cpu: Intel I7 3930K@ 4.7 OFFSET 1.328\1.336 Cooler: H100I Ram: 16 Gb Corsair Platinum 2400Mhz C9 Gpu: EVGA GeForce GTX TITAN Superclocked Signature 6 GB Ssd: samsung 840 Pro 256 Gb+samsung 840 evo 120 Gb+ASUS ROG RAIDR Express AUDIO: ROG Xonar Phoebus 7.1+ logitech Z-906 MONITOR: MX299Q ULTRA-WIDE 21:09 ALIMENTATORE: Corsair AX 1200i OS: Windows 8.1 pro 64 bit ROUTER: DSL-N66U
8 REPLIES 8
Dark
Can you please explain more clear what the problem is as I'm confused do you mean the pc temp or outside
40degrees is normal and most users would be very happy at that.
motherboard ASUS Crosshair V Formula
PSU Fractal Design Newton R2 1000W
MemoryRipjaws 16 GB
CaseArmor Mx
CPUAMD Bulldozer FX-8120 8 Core 3.10GHz
Clocked to 4.5GHz
Im a girl 🙂 so be nice as i bite
Arne_Saknussemm
Level 40
HI there! 🙂
Your offset is a bit complicated to find. Basically you have to enter a guess value for offset and see what your load voltage is in CPUz. You know the CPU is good at 1.355 so try a few values in offset until CPUz is giving you 1.355 under load.
This is a good guide; http://rog.asus.com/forum/showthread.php?2162-Overclocking-Using-Offset-Mode-for-CPU-Core-Voltage&co...
Maybe start +0.01
I'm sorry
I meant that the temperature outside is high
I understood very well Arne
Arne Saknussemm wrote:
HI there! 🙂
Maybe start +0.01
Hello friend
I tried to -0,005
idle:
[IMG] http://i.imgur.com/DIFjm.jpg [/ IMG]
full:
v-core 1344 + or-
I wish I had 1.355V in full, at which rate was stable with no offset
So I try to -0.01?
after lunch I also read the guide!
by 1000
Dark
Oh.I.see what he.means now the CPU voltage offset values oh
Well I don't.know that stuff.
MemoryRipjaws 16 GB
CaseArmor Mx
Clocked to 4.5GHz
Arne_Saknussemm
Level 40
Hmmm...Maybe try a very small positive offset like +0.005 or +0.01 see what load gives you
HiVizMan
Level 40
If the temps are too high outside then you need to try lowering your base vcore and having a + offset.
That way your base vcore is low = low heat and when you need performance you get the extra voltage.
Anicra
Also depend on the LLC (load line Calibration) you are running. For example on 3960X High LLC 100 x 49 , I have to use +0.030 to keep it stable however if I switch it to Ultra High LLC I can get by +0.005. I personally think the graphing table on OCCT 4.3 is nice to have to see the shifts in V core. Granted on extreme loads I know I need to keep it near 1.440V or I get BSOD x101
I7 5960X/Asus RE5u3.1 -3101/64gb(16x4)@3133 @1.39V Gskill 14-15-16-36 cr2/3xTitanX/ WD RE 6.0 TB RAID 0+1/Samsung 840 Pro 256 x2 Raid 0/Samsung 850pro M.2/Asus Essence One/Corsair Ax1500 PSU /Corsair Obs 9800D case/ 3 2xRad 120x3 and 120x1/ EK MB block/AquaC Kryos CPU/Koolance GPU x2/ Bay 452x2(ver2) (2x655 serial)
thanks a lot man, but no 00:01 minimal set is 0,005.
I decided to leave the v-core of fixed assets and keep the energy savings, so the multiplier drops to x12 when I do nothing ....
Then, fortunately, the heat is ending xD
As I said above I'm happy just drops the multiplier when idle.
Then next summer we go to offsett ...
many thanks to you too man
LLC I always keep on height, so as to have the v-core in the bios the same as what I see in the desktop ...
thanks a lot man
