OC Corsair Dominator GT 16Gb 2400Mhz
Metaltoby
I want to overclock the CDominator GT to 2400Mhz!
System
Case: CM Storm Trooper
Mobo: Asus Rampage IV Extreme
RAM:CorsairDominator GT 16GB DDR3-2133 CL9 quad kit
CPU: Intel Core I7 3960X
GPU: 3x Sapphire Radeon HD 7970 3GB
SSD1: OCZVertex 3 Max IOPS 120GB
SSD2: OCZ Vertex 4 128 GB
HDD: Samsung 1TB, Samsung 500GB
PSU: EnermaxMaxRevo 80+ 1500W
Monitor: DellUltraSharp U2711
OS: Windows 7 x64.
24/7 Bios
CPU ratio: 46
Bclk freq.: 100
Vcore 1,37V
all DRAM: 1,5V
CPU VCCSA: 1,23
CPU PLL: 1,7V
VTT CPU: 1.2V
I've have tried the bios on auto with the DRAM voltage on 1,65 and DRAM freq on 2400Mhz = failed
Is there anybody who can help me to reach the 2400MHz?
Thnx in advance...
l Asus Rampage 4 Extreme l intel 3960X@ 4800Mhz (1.4 volt) 24/7 l 3x Sapphire HD 7970 1200Mhz/1600Mhz Corsair Dominator GT 16GB DDR3 2133 CL9 l Enermax Max Revo 80+ 1500W l OCZ Vertex 3 Max Iops 120Gb l l OCZ Vertex 4 128GB l Samsung F1 1Tb l Samsung F1 500GB l Corsair H100 l CM Storm Trooper l Dell Ultra Sharp U2711 l 2x Verbatim Store N' Go 2 TB USB 3 l Dell Ultra Sharp U2711 l Logitech X-230 l
26 REPLIES 26
Metaltoby wrote:
I Followed your advice and i only loosen the timings to 10-11-11-28 and afterwards the system booted up.
I did a memtest at 2400 MHz. No errors found!
Thank You very Much mate!
no worries mate glad to help out.
13485
that you used for the ram voltages?
HiVizMan
Level 40
Well done to all involved.
thank you, you too!
Stu
Great topic - rushing home to try mine out at once as mine are struggling even at their rated 2133. 🙂
Asus Maximus IV Extreme Z
i7 3770K @ 4.4ghz
AMD 7970 HD x3 in TriFire @ 1200/1800.
2x 240GHZ OCZ Vertex 3 SSD & 1x 512Gb Vertex 4
16GB 2133mhz Patriot DDR3
Ennermax Max Revo 1500w PSU
Huge water loop with an internal EK 340mm & external Supernova 1260mm
Windows 7 64 bit.
Aquaero Fan control & monitoring
rog-classified
just wondering is there a big different between CorsairDominator 2400mhz vs kingston hyperx beast 2400mhz. i bought Kingston beast 2400mhz 32gb. is there any different when overclocking? or am i screwed:(
It ain't over till the fat lady sings :cool:...
Daveo
Level 11
Hello,
not quite sure what you were asking in your post but I will answer in this way.
The differences may vary from kit to kit. if your hardware is capable of 2400mhz, these differences may just be a matter of timings and voltages, though with 32gb capacities, its highly probable that youll need to make some changes to the cpu/memory controller, in addition to any ram tweaks. Keeping in mind CR command rate will likely need to be changed to a value of two, for 32gb capacities and higher- can confirm this for x79 chipsets.
Actual differences in performance at 2400mhz between vendors will be small, unless youre comparing dual channel against quad channel.
But I think you are safe, kingston make some fine hyper modules.
Daveo
