Noctua D15 Problem
allocen
So in the next couple of days i'm gonna give my noctua D14 to my father's new pc buid and i plan buying Noctua D15 but i'm not so sure that it will in my pc due de +5cm that noctua d15 has.
Motherboard: Maximus Vii Formula
Case: Zalman Z11 Plus
Processor: i7 4790k
Ram: 4x 8gb hyperx savage @ 2133 mhz
Please, this is kinda urgent and i need an answer if anyone knows exactly if it will fit.
Heini
Level 11
PCPartpicker has a neat function. I looked under your case model and then compatible CPU coolers and the Zalman Z11 Plus is compatible with the Noctua NH-D15.
allocen
Thank you, then.
