need help with SLI settings
Si1verSmoke
First off I would like so say whats up my fellow gamers :-). I have a question. My rig consist of
- i7-3930K (6 core)
- Asus Rampage IV Extreme mobo
- 32gb 1866 DDR 3 Dominator GT Ram
- Force GT 240gb SSD
- (2) SLIed EVGA nVidia Geforce GTX 680 2gb DDR 5 Super Clocked
- Corsair AX1200i power supply
- Corsair H100 liquid CPU heat sink
- Corsair Obsidian 800D case
- Windows 7 x64 Ultimate
Now I was wondering what would be the best settings to have in my Nvidia control panal and second, when playing Far Cry 3 my frame rate is crap, I am showing 15 FPS. How do I boost my frame rate all around with all games and what kind of setting should I be running my 2 GPUs at in the control pannel?
Thank you for your time.
- i7-3930K (6 core)(OC 4.25)
- (2) SLi EVGA nVidia Geforce GTX 680 2gb DDR 5 Super Clocked
6 REPLIES 6
ronmolina
Not trying to be funny but make sure sli is turned on.
Si1verSmoke
No thats cool. It is turned on.
Myk_SilentShado
Level 15
Have you gone to the FC3 Forums to see if there are any tweaks for SLI? you may have better luck there, may need to do some settings editing and i'm guessing there's probably a plethora of info for the taking 🙂
Si1verSmoke
as simple as that seems I cant beilieve that I didnt think of going there. lol, thank you.
Lol no worries, sometimes it takes an outside influence to remind us of the stuff we oftentimes forget, or over look 🙂
Chino
Level 15
Are you running the 310.9 NVIDIA drivers? They fixed a lot of things for the GTX 680 and FC3 especially the SLI profiles.
