Need help with OC crosshair v formula z and fx8150
Korvan
CORSAIR Dominator Platinum 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400
AMD FX-8150 Zambezi 3.6GHz (3.9GHz/4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor with Liquid Cooling Kit
KINGWIN LZP-1000 1000W ATX 12V v2.2, EPS 12V v2.91, and SSI EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS PLATINUM
HIS IceQ Boost Clock H795QC3G2M Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
ASUS Crosshair V Formula-Z AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard with 3-Way SLI/CrossFireX Support and UEFI BIOS
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full
Since day 1 of my build I seem to have issues with OC. I posted in the forums awhile back and didn't get to far.
I have since then not oc'd my system at all. I can test all hardware and tests are good. I can wipe my HDD re install everything and still get random freezing and have to force reboot or like as of late i get glitches in os. I have like in background 12 images setup to rotate and they sometimes ghost each other overlapping like both are present at same time,
Also if I run any type of registry cleaning software whole system will lock up causing force reboot
I have made sure all drivers and windows updates are up to date and begin to wonder if hardware was never good from the beginning. My ram I am not sure if fully compatible with the MOBO BUT i seen some say it is.
I really need any help I can get I had my previous build last me 7 years with not half the specs of this system and it still runs to date without any issues.
I am currently running windows 8 64 bit as well. I have Govt issued symantec endpoint protection running and no other crap on it but games and some basic software applications.
Any advice on hardware or how I might need to setup Bios. Please dont refer me to the crosshair v formula z and 8150 OC guide. I simply dont get from it enough to oc my rig. I feel there is something missing or perhaps I am too much of a noob and got lucky on my first build.
Ty again for any quick responses
160 REPLIES 160
HiVizMan
Level 40
700w is fine for what we are doing stick it in and see if there is any difference.
Korvan
I will plug the 700 watt in today after work. I have to pull it form another system
HiVizMan
Level 40
No worries mate, will check back tonight.
Korvan
30614
So this is my 700 watt PSU at stock and its producing same results.
Now I am beginning to think its not my PSU.
I am going to pop my old one back in and clean it up while waiting on ya response
Korvan
Got my old PSU back in so now what ya think
Poco_OM
I am waiting on HiViz to reply as I am not 100% sure.
I may borrow a tester but that will be this time next week at the earliest.
I have a couple of other theories that I would like to rule out, one being the VRM's. Hopefully the water blocks are in stock by this time next week as everywhere I look they are not in stock. Looks like I have to have an EK also.
Korvan
I have a tester but multimeter so I can do that. But very odd 2 psu showing same thing. And that 1 has been in a over clocked system for 6 years no issues. I feel it's my board or something else simple I'm missing
Korvan
Did I lose yall lol
Until I hear from yall
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118145
Is that any good or do you think stock watercool that came with my 8150 is good?
Where you guys disapear off too lol
HiVizMan
Level 40
Hello again - did not loose any one just that most of us have a life too. Went away for a long weekend but back now.
If you are comfortable with the PSU then all good.
Lets move on.
Can you please do the 22 x 200 settings use VCore of 1.425 for now.
Lets move on.
Korvan .. Sorry for your issues M8 .. don't know how I missed this Thread, my apologies. And if I have neglected to
say so before .. Welcome to ROG, Please Pardon my Manners.
Give the above a shot, I would add one other - CPU/NB manual to 1.4 as well ..
Can you take a pic of your rig set up to confirm wiring [please, no offense, just want to help]
Do you have any other monitoring software loaded ? aiSuite ??
Please give the above a go and post a screen of HWmonitor .. and cpuZ x2 .. one of cpu other of memory ..
Your voltages are all over the place .. so as suggested already it can be but two things .. the psu or the board ..
[or some of the board settings .. we will look at that more if needed]
Best of Luck .. watching this thread with great interest. .c.
