Need help with OC crosshair v formula z and fx8150
Korvan
CORSAIR Dominator Platinum 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400
AMD FX-8150 Zambezi 3.6GHz (3.9GHz/4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor with Liquid Cooling Kit
KINGWIN LZP-1000 1000W ATX 12V v2.2, EPS 12V v2.91, and SSI EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS PLATINUM
HIS IceQ Boost Clock H795QC3G2M Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
ASUS Crosshair V Formula-Z AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard with 3-Way SLI/CrossFireX Support and UEFI BIOS
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full
Since day 1 of my build I seem to have issues with OC. I posted in the forums awhile back and didn't get to far.
I have since then not oc'd my system at all. I can test all hardware and tests are good. I can wipe my HDD re install everything and still get random freezing and have to force reboot or like as of late i get glitches in os. I have like in background 12 images setup to rotate and they sometimes ghost each other overlapping like both are present at same time,
Also if I run any type of registry cleaning software whole system will lock up causing force reboot
I have made sure all drivers and windows updates are up to date and begin to wonder if hardware was never good from the beginning. My ram I am not sure if fully compatible with the MOBO BUT i seen some say it is.
I really need any help I can get I had my previous build last me 7 years with not half the specs of this system and it still runs to date without any issues.
I am currently running windows 8 64 bit as well. I have Govt issued symantec endpoint protection running and no other crap on it but games and some basic software applications.
Any advice on hardware or how I might need to setup Bios. Please dont refer me to the crosshair v formula z and 8150 OC guide. I simply dont get from it enough to oc my rig. I feel there is something missing or perhaps I am too much of a noob and got lucky on my first build.
Ty again for any quick responses
160 REPLIES 160
Korvan
I am sorry did not mean to be disrespectful.
And I will do this moment I get home.
Do you not agree that it is weird both my PSU display same readings and 1 is in a OC system that has never had issues?
HiVizMan
Level 40
I think it is very strange to be honest.
I have a couple of new Crosshair boards on the test bench as I will be benching some 32mil tonight I can check them all and see if it is board specific or PSU specific.
Korvan
Your the man thnak you for your assistance
HiVizMan
Level 40
In for the journey mate, not just the destination.
HiVizMan
Level 40
Good to see you in this thread Chris, could you step up and take over as a equal partner please. Your time zone will make real time corrections so much easier.
chrsplmr
Level 18
Yes indeed .. we are only 3 hours apart .. I will await his 'arrival' ..
The 12v rail is weak in this PSU as well .. a 'new' one wouldn't hurt unless it
reveals the same result .. which would tell me it's a board issue ..
What bios version OP ? I saw that you flashed the bios .. what version ?
Can you confirm that it was from this page ?
http://www.asus.com/ROG_ROG/CROSSHAIR_V_FORMULAZ/#support
Also DRam should be set to 1.65
Worry not bro .. we will get this sorted .. .c.
4 PSU's, 2 Mobos and the same readings on all, 600w 700w a 1000w if my memory serves me and a seasonic 1250w.
I am leaning heavily to the mobo, VRM's to be specific.
HiVizMan
Level 40
Chris was saying the exact same thing to me a few minutes ago when we chatted about this. It does look more and more like board issues.
chrsplmr
Level 18
I'd love to see a screeny of the board with adjusted digi .. and manual settings in place as indicated above ..
[hwMonitor, 2xcpuZ-CPU/Memory] .. but have to agree, the leaning is 'almost' to the tipping over point. .c.
I will leave that to the OP as this is his thread that me trying to help has highlighted a problem with my own system.
Getting it resolved is something I am keen on, and I have been through all I know so if your suggestions work or come up with things I have not done or considered, I am all ears. Just wanted to point out that the PSU's are looking less likely than the mobo, or maybe the CPU's.
