Need help with my build please
mykelbuenrostro
Current setup:
Motherboard: Asus Maximus VI Hero
CPU: Intel i7-4770k
CPU Cooler: Stock
Memory: Trident X 16Gb
Case: Cooler Master HAF 912
My problem is this .. I've been looking for a new CPU cooler, air cooler / water cooler and I'd love to go with a water cooling option however my case seems to not support the best options like for example:
1. Corsair h100i
2. Swiftech 220.
I've also considered the following air coolers:
1. COOLER MASTER RR-V8VC-16PR-R1
2. Prolimatech PRO-GNSS-BK
Those 4 would be my top choices but I want something that fits inside my case and I'm not sure either of those water cooling options do. What do you guys recommend based on my build. I'd love the best possible result considering my case and to be able to OC to around 4.5Ghz without having to worry about temperatures.
10 REPLIES 10
Chino
Level 15
Welcome to the ROG forums, mykelbuenrostro.
You can fit the H80i in the HAF 912 easily. And the H80i's performance is pretty close to the H100i. 😉
Thank you very much for the suggestion! I don't even know how the other day I was OC'ing my system to 4.2Ghz on the stock cooler, temps were at about 58c lol.. I had to revert those changes back to default, I have no idea how that even happened lol. I heard that there should be no stock cooler OC'ing b/c of the risk.
Chino
Level 15
Here's the funny thing. Technically you can overclock using the stock cooler. Depending on the quality of your CPU and the extra voltage needed to get there, the increase in temperatures might not be that big. The problem comes when you apply a load to the CPU. You'll see an immediate increase in temperatures.
For example, your temperatures were about 58C because you probably weren't doing anything on your system. But if you had started gaming or doing heavy tasks on it, you'd see that 58C go up to 70C - 80C. LOL
Masterbobo
yea the h80i should work for you. or any other all in one water cooling kit, mine installed in less then 5 mins and stays cool. OR you can setup your own custom water cooling system.
Rampage IV Extreme
55" Samsung 3D LED 1080p
19" NEC side monitor
4930k @ 3.9ghz (h100i)
Dominator GT 2133mhz 16gb
2xDomiatorGT RAM cooling fans
OCZ Vertex 4 RAID0 2x256gb
Silent Pro GOLD 1200
3xGTX 770's 4GB Windforce TRI-SLI
Sound Blaster Zx
Logitech Z5500 digital 5.1
2xLG 3D Blu ray burners
Silverstone Multi USB3 card reader
2x4terabyte WD backup sata6.0 drives
1x1terabyte WD backup sata6.0 drive
10 Antec tri cool 120mm fans
Razor Deathadder mouse
Corsair 600t
Win7-64bit
mykelbuenrostro
Thank you both for your input, I ordered the h80i today along with some Cougar CF-V12HP fans to replace the stock fans since I heard the stock fans are loud.
HiVizMan
Level 40
Post up some images once you are done with your build.
Yes, I'll be sure to post pictures of the completed build.
LukeeVassallo
You'll overclock to 4.5ghz with the H80i even to 4.8ghz... If the case permits do a psuh pull config.
| Maximus V Formula | i7-3770k | 16Gb Dominator Platinum | GTX 780 | Force 240Gb | 2TB Caviar Green | Obsidian 650D | AX850 | H100 | 24" LED VS247H |
That's what I'm looking forward to 🙂 and yes it does, HAF 912 😛
