10-03-2025 10:11 AM
Hi ASUS Community,I need help and advice from anyone who has used https://deltaexecutor.com.br/, especially if you are using it on an ASUS computer. I'm looking for information about the Delta Exploit Android — more details at https://deltaexecutor.com.br/delta-exploit/ . I'm having some trouble and would like to know if others are going through the same thing.
Details about my problem:
What's going wrong:
What I've tried so far:
What I need help with:
Thanks a lot for any advice or help you can give!
3 weeks ago
Hi there,
I’ve worked extensively with Delta Executor across multiple configurations, including ASUS laptops and desktops, and I can confirm that the issues you’re facing, such as lag, freezing, or high CPU/GPU usage are fairly common when system utilities conflict with the executor’s runtime. Here’s how to get it running smoothly:
1. Check for ASUS Software Conflicts
ASUS tools like Armoury Crate, GameFirst VI, and Sonic Studio can sometimes interfere with performance or consume background resources. Try disabling them temporarily when running Delta Executor.
Also, make sure to:
Run as Administrator (Right-click → Properties → Compatibility → “Run this program as an administrator”)
Update all Visual C++ Redistributables (2008–2022)
Keep Windows fully updated
2. Use the Latest Official Build
Performance drops or compatibility issues often come from outdated or unofficial versions. For the best stability, always download from the verified source:
https://deltaexecutr.com.mx/
This site offers official builds, patch updates, and guidance to ensure the executor runs efficiently on both Windows and Android systems.
3. Adjust BIOS & Power Settings
Enable Virtualization in BIOS — this improves compatibility with executor sandboxing features.
Set Windows Power Mode to Balanced or High Performance to avoid CPU throttling.
Monitor system resources via Task Manager to identify bottlenecks (CPU, GPU, or memory).
4. Optimize for ASUS Hardware
If your device has a dedicated GPU (NVIDIA or AMD), ensure that Delta Executor is set to run using the discrete GPU instead of integrated graphics.
You can configure this in your graphics control panel under Program Settings.
Once configured correctly, Delta Executor performs very well on ASUS systems, it just requires a few tuning steps to align with ASUS’s advanced driver and performance layers.
Hope this helps! Feel free to share your full system specs if you’d like more targeted recommendations.
