Need help Undervolting my 9900X CPU
wade777
I would like to Undervolt my 9900X CPU to just lower the temp's,I have watched a lot of video's on what program's to use like Cinebench Prime95 and OCCT to check the stability of the system after each voltage adjustment so I don't need any help that way.
Where I do need help is that I can not find in the bios of my X870E ProArt where go to lower the voltage of the cores,I have look under AI Tweaker but I can not find the setting,I have found where to set my CPU's Max Boost speed.
Can someone please tell me where to find the area I need to be in to lower the voltage that the core's get,also do I need to Enable or Disable anything to get a menu in the bios to so I can adjust the voltage of the cores.
0 REPLIES 0
