Need help overclocking in Asus Sabertooth 99FX R2.0 mobo
brkkab123
I need help applying settings I got from AMD Overdrive in Windows * Pro w/WMC x64 to my Asus Sabertooth 990FX R2.o's 1903 uefi.Overdrive got my AMD FX 8350 to 4.5 GHz. I made 3 screenshots in Windows 8 and printed them and then uninstalled Overdrive after running benchmarks.
Chino
Level 15
Just look for the corresponding settings in your BIOS and change it. Usually you don't need to touch anything more than the multiplier and vcore options.
HiVizMan
Level 40
Could you report back how this panned out please.
I tried the setting's AMD Overdrive used in the uefi (version 1903) and pc became unstable. I set uefi to optimized defaults and have left it alone.
