I recently bought this kit for my EK waterblock:
https://www.ekwb.com/shop/ek-supremacy-precisemount-add-on-naked-ivyMy cpu was already delidded a few years ago so I thought why not.
Temps before “naked mount”:
https://drive.google.com/open?id=0B9CyJiyzx3DlNV9JcWZ3ZkdTaHcAfter:
https://drive.google.com/open?id=0B9CyJiyzx3DlMmhkTFl2UnJoNFUIt's been really fun to overclock the last few days but I seem to have hit a bit of a wall on 4.9ghz / 1.44v. It's quite stable but not enough for 24/7/365.
Some documentation I’ve done:
https://drive.google.com/open?id=0B9CyJiyzx3DlZ2w1M2xXQmg4S2sI’ve been running “eventual CPU input Voltage” at 2.01 before on my other overclocks. But now I seem to run into instability no matter what, input 2.3v, vcore 1.55v, doesn’t matter after starting occt it fails after 10 seconds to 2-3 minutes. 4.8ghz / 1.4v vcore / 2.1v input seems good and ran between 4 and 5 hours occt stress test before it failed, probably needs a little bumb on voltage, haven't had the time to test more yet. It boots to 5ghz but can’t really do anything other than screenshot it. So my goal would be 4.9.
I’m a little uncomfortable increasing my input voltage above 2.1v. But if it dies, whatever, it will suck but I got money saved up for a new pc parts (cpu/Mobo/ram). Not sure if anyone has anything to say about where the limit is with the input voltage?
Stats from my previous overclocks on this cpu:
(Input voltage : 2.01v
😞4.4ghz / 1.18vcore / 4.4ghz ring/ 1.2v adaptive ring
4.5ghz/ 1.26vcore / 4.5ghz ring / 1.3v adaptive ring
4.7ghz/ 1.38vcore / 4.5ghz ring / 1.3v adaptive ring
(Input voltage : 2.1v):
4.8ghz / 1.4vcore / Auto ring / Auto ring voltage (stable)
4.9ghz/ 1.44vcore/ Auto ring / Auto ring voltage (unstable, kinda ok for daily use tho (5h of linpack was fine))
(Input voltage: 2-2.3v)
4.9ghz/ 1.4-1.5v. (anything above or below 1.44 makes it more unstable:S)
(C states / turbo / EIST / spread spectrum / and a bunch of other things disabled to eliminate instabilities when I’m overclocking.Vcore on manual. Most other voltages and settings on auto)
I’m not that patient with reading forums so if anyone has any ideas for previous experience I’d LOVE(!) if you could help me out. (probably get a lot of these “stupid” questions/ posts)
(I suppose you need some of my bios information may be, I can add that to the google drive, but what, my overclocking profile on a file or something like that?)
4770k
Asus z87 gene
16gig 1600mhz cl8 ram
Corsair AX860i PSU
3x 140mm rad with custom watercooling on the cpu (420 blaze it)
