Need Advice...
DeathGod
Hello i tried my 1st overcloking and i got this result.
Ai overcloker >X.MP
Core ratio 4.5
Vcore > 1.275
Ram:1866
and the rest all auto.
should i try with more lower vcore? or this is already good for 24/7?
Temp in full load max is 62c and Vcore is 1.246
14367
||Mobo||Asus Maximus Formula V||CPU||i7-3770k||Ram||Corsair Vegeance 8GB 1866mhz||
||GPU||Asus GTX 560 1GB DDR5||SSD||Samsung 830 Series||Cooling||Corsair H100||PSU||Corsair 700w Gaming
17 REPLIES 17
DeathGod
well.. what is the easy way? speedstep or on OS? coz im really dnt knw where i need to start in speedstep 😞
HiVizMan
Level 40
If you have set a manual voltage your voltages will not change. Simple as that.
Speedstep if you have no idea where it is you have not changed it so all good.
Power plan is in your OS, and again if you have not changed it then it is still on defaults.
HiVizMan
Level 40
Yeah the LLC extreme was pumping in extra voltages to manage the droop when under load as I thought - you have two choices.
1 Go back to extreme, you know it worked and you know your system was stable.
2 Or, find a vCore that does work with LLC at regular or medium.
DeathGod
ok thanks Sir 🙂
DeathGod
Update:
i think i found the right vcore for medium LLC
new Setup:
Cpu 45x
vcore 1.65 (Bios) full load in windows 1.216v
Ram: from 1866 downgrade to 1600 coz i tried with default setup just using Xmp 1866 crashed thats why i change to 1600.
15x runs in intelburntest success..
there another things i need to setup?
Thanks
HiVizMan
Level 40
Think you have it done and dusted mate. Solid oveclock and will max out any PCIe bandwidth needed for optimal VGA performance.
Just enjoy your system is what I can say is left to do.
DeathGod
Thanks again for all the help i receive from this my first experience in overcloking 🙂
btw.. i need some advice for new GPU im thinking to buy before xmas my budget is 350eu.
HiVizMan
Level 40
Only need to decide AMD or nVid
If nVid 670
If AMD 7950
