This is my first real system build; every other build I have done has been with used parts or with very cheap ones. Needless to say I am in need of some advice about configuring everything.
I have the MVE motherboard with the 3770k processor, dual GXT-670 4GB video cards and 16GB ram. Everything is working fine (I think) but I am not sure I have it set up right.
I cannot get the updated drivers for the video cards to install. Took me 3 tries to get SLI to stick and 3DMark advance is choppy when I believe it should be smooth, but it finally says SLI yes.
I installed the Hyper 212 EVO to insure I don’t hurt anything which just made things more confusing. I had to change settings in BOIS because the fan speed was so low on the cooler I kept getting a boot warning.
I have a 240GB sata SSD drive with my operating system and a 256GB msata SSD I split; half for storage and the other half for back-up. I haven’t created all the folders and moved the files yet, still reading about how that is done and what folders to move (suggestions?).
I don’t know what questions to ask because I think it is mostly personal preference, but I am sure you could offer suggestions as to configuring it for best results.
This site has been a great help to me and I could use some suggestions before I get too far and have to start over. I play a few games and dabble in DAZ 3D and Hexagon 2. I hope to get this right and tested before the case arrives so I am able to start installing water blocks and getting this puppy running at peak potential.
I just ran 3D mark strike force on extreme setting and the choppiness was intolerable. What am I doing wrong?
