MPCIE Bluetooth/wireless adapter wire broke need to replace it
alanwest09872
Ok the wire that goes from The MPCIE to the IO SHIELD has broke. I need to replace that wire. So how do I go about doing this.
I have the ASUS MAXIMUS FORUMlA VI 6
The wire btw just clips into the MPCIE adapter thats why I am hoping just to replace the wire.
This is improtant to me. Its the Last piece of my system that I need to get perfected
kkn
Level 14
if you are lusky ( that is IF you are LUCKY ) you can trawn used parts or see if you can find new connectors online, like ebay or amazon or things like that.
of IF there is one who dont use the mpcie wifi/BT card that can provide the cables for you.
