?? memory info for formula v MB
nufc179
hi all just a quick ? will a set of (CORSAIR CMX4GX3M2A1600C9(XMP) 4GB(2 x 2GB) DS - - 9-9-9-24 1.65) work all right with this MB & will it be ok to run 2 sets of this RAM = 8GB(4 x 2GB) on the MB thanks in advance
Zka17
Level 16
It may work... but it isn't really recommended to mix two different kits... - even if they're seeming the same (based on their stickers), they're not exactly the same... however the IB has a pretty strong IMC and should deal with those low clocks...
If you have the budget, better to check some GSkill TridentX kits... a 2x4GB or if you need more RAM, a 2x8GB kit would fit nicely that platform...
