Maximus XI Formula memory wont go over 3400MHz
Pesari
Hi, any suggestion how to get my g.skill trident z rgb 2x8gb 4000MHz go more than 3400MHz?
I have tried xmp profiles, manually tweak timings and voltages. Anything over 3400MHz and my computer boots to safe mode and back to bios. Pc tries about 3-4 times, couple of seconds and then shut down and safe mode.
I did have same problem with my HyperX Predator memory 4000MHz. Anything over 3400MHz is no go.
I have lates bios. Motherboard supports those memory*
I have tried bios at default and then xmp and with oc, but nothing changes.
Pc specs.
I9-9900K
Evga RTX 2080 TI
Maximus XI Formula
G.Skill Trident Z RGB 2x8GB 4000MHz
Corsair RM1000x
2x500gb ssd
Custom loop*
Im out of ideas.*
12 REPLIES 12
Pesari wrote:
Did not know that only 2 dimms can be problem. I have had always 4 dimm slot mobo and used only 2 of them. But those times i did have only 3200MHz kits and different mobo.
Well i dont need more than 16gb memory and *another 355e for memory kit is not woth it.
I have tried with different slots and different voltages. And both xmp 1 and 2. Tweak mode 2 is something that i have not tried yet.
Is it possible to cause same problem if i put too much voltage for vccio or vccsa?*
Tuning VCCSA / VCCIO may help. You may want to try the Tweak Modes first, though. Most users favor populating all DIMM slots, which is favored by the T-Top trace layout. This doesn't mean the kit won't run at 4K, but tuning can often be needed.
Hagmak
did you manage to achieve higher frequencies? I can't get over 3200MHz with the same hardware. No matter what I try, I get bluescreens or can't even load into Windows when going higher than 3200.
Thanks in advance.
Hagmak
Aurosonic
Try A2-B2 slots combination. I had this issue when inserted A1-B1 combination
9900k@5200@1.35v LLC5/Apex XI@0231/G-Skill F4-4600C18D-16GTZR/Aorus 2080ti xTream Wateblock@2100/8100
