Hi all, recently purchased a 6700K, Maximus Ranger VIII and 16GB DDR4 3000. Mostly the performance of everything here is superb, I don't think there are any hardware technical faults with the components, but I still have a few niggly problems that are strange to me. I am not overly experienced with the technical side so bare with my novice terms.
Problem 1 - Problems restarting Windows 7
The PC shuts down fine and boots from cold fine, but occasionally when installing Windows Updates which asks me for a restart, the machine powers down normally, restarts, but fails with Q-Code 55 (No Memory?) I'm forced to shut down the system. When I restart, the ASUS screen says "Overclocking Failed! Enter Setup to continue" which I do. Nothing is overclocked, but my memory is running an XMP profile for 3000Mhz (which is what it was designed to run, I don't class this as overclocking?) System never crashes in games or in windows, just during restart.
Problem 2 - Weird USB connectivity issues
Transfer rates from external devices is really bad, sometimes when connecting memory stick or external drive, the device seems to lock up? Spinning circle, green bar loading forever when trying to access in My Computer. I'm thinking could this be related to XMP and overclocked memory or not? Seems a weird issue.
Problem 3- Slower boot time than my old 2600K with Asus P8Z68-V PRO/GEN3.
This isn't really a big problem as such, more a query as to ways to improve boot time. The mobo seems to take a while to get into Windows. I'm not talking minutes, but quite a bit longer than my previous system that posted almost instantly. As far as I know, the fast boot options are turned on, and the OS is installed on a SSD in 6GB/s SATA port.
By the way, the mobo is running the BIOS 0508, I know there are more recent versions, but my Asus Suite is telling me not to update from this rev. Why? :confused:
Thanks all.
