Has anybody had an issue with a Maximus VI Formula motherboard where the PC turns on, then off in three seconds, then on again, where it stays on? I have had the PSU and Ram tested at microcenter, both are working fine. After the computer turns back on, the led codes give the all clear, but clearly something is wrong. Are there any solutions to this problem? Is it a BIOS fix, or just a problem with the motherboard?
Thanks for any and all help.
