Maximus VI Formula not detecting PWM fan splitter
SnipeAHolic12
I just purchased my Swiftech H240-X and I used the included PWM fan splitter. I attached my fans to the splitter, connected the splitter to the CPU_FAN spot, and below I attached the CPU Block to the CPU_OPT port. When I boot, it does not detect the CPU fan. All the fans connected to the splitter are spinning. When I go to BIOS to control the fan, they do not slow down. What is the issue? Any help would be amazing.
Quad5Ny
How many wires are going to each fan? There should be 4 going to one fan and 3 going to the other (only one fan should be feeding the RPM sensor). My EVGA Hadron came with a splitter that had the tach (RPM) sense going to each fan.
Have you tried a single fan on the header? Have you tried a full power cycle (turn off > wait 20 seconds > turn back on)?
Also are they Corsair SP120's? Because there was a bad batch at one point.
SnipeAHolic12
The two fans that came with the cooler are 4pin PWM fans. The other two I have in the splitter are 3 pin fans. I have all the fans connected to the splitter, and the PWM switch connected to the CPU_FAN header on the Maximus VI Formula. The CPU Waterblock has and LED fan that I plugged into the CPU_OPT right below the CPU_FAN header on the mobo. When I go into bios and monitor fan speeds, they are all N/A.
Right away there was a CPU fan error, I had to set the 600 RPM rating to Ignore to get rid of the CPU Fan error. If I go to 200 RPM, there is still an error.
