04-27-2014 08:24 AM
04-28-2014 08:26 PM
04-29-2014 06:38 AM
04-29-2014 07:31 AM
MattDeox wrote:
Hello,
I've just setup my computer and used Fan Xpert 2 to tweak my fan speeds.
I'm using a corsair h105 aio water cooler as cpu cooler.
The pump has a 3 pin fan connector and is connected to CPU_FAN. The two fans cooling the radiator are PWM controlled and are connected to CPU_OPT.
Now why is the CPU_OPT rpm showing in Fan Xpert 2 while I cannot really control the rpm. Only CPU_FAN and Chassis fan 1-3 is possible.
Back to my actual problem: Because the 3 pin pump connector is connected to the PWM CPU_FAN it is always running at full speed and cannot be controlled with fan xpert.
I've read that I could set the CPU_FAN's rpm to be controlled via voltage but I didn't find the setting for that.
Could somebody tell me where to look?
Also if I set the CPU_FAN to be voltage controlled, will the CPU_OPT PWM header still use PWM or will it also use voltage?
Thanks in advance
