I got a matrix 780ti gpu and I have a weird problem. I hooked up the card into the first pci-e slot and windows worked fine. However, when I play a game it crashed, every single time on 4 different games (crisis 3, metro LL, TB and Spec Ops the line). After checking power cables and installing the latest drivers I still got the same problem. Then I swapped the card into the 2nd slot and worked fine without any problems.
The thing that is bothering me is that the motherboard is not functioning properly, I have experienced a similar problem with a previous card, a black screen after boot up. Is there something that can be done about this or anybody with the same problem?
Looking forward to your replies
| Maximus V Formula | i7-3770k | 16Gb Dominator Platinum | GTX 780 | Force 240Gb | 2TB Caviar Green | Obsidian 650D | AX850 | H100 | 24" LED VS247H |
