Loose Battery ( G750JW)
Lucas_Cardoso
I have noticed that my laptop battery (ASUS G750jw) seems loose, 2 mm maximum. I wonder if this is normal or not. The laptop still works perfectly. thank you
Zygomorphic
Level 17
@Lucas Cardoso, welcome to ROG! 🙂 Actually, all the batteries have a tiny bit of wiggle in them (that's how you get them in and out :)). 2mm seems a little high, but if the battery is clipped in and can't fall out, I wouldn't worry about it.
I am disturbed because I cannot break my system...found out there were others trying to cope! We have a support group on here, if your system will not break, please join!
http://rog.asus.com/forum/group.php?groupid=16
We now have 178 people whose systems will not break! Yippee! 🙂
LINUX Users, we have a group!
http://rog.asus.com/forum/group.php?groupid=23
