07-04-2018 08:31 PM - last edited on 03-06-2024 08:30 PM by ROGBot
07-04-2018 10:18 PM
07-05-2018 03:37 AM
07-06-2018 05:40 AM
07-06-2018 09:24 AM
Zammin wrote:
I have changed some settings on my 5Ghz overclock due to the AVX offset constantly kicking in during gaming. I'm at the same voltage and LLC but I've increased the CPU current capability to 140%, raised the cache ratio to 46 (any higher causes instability) and changed the AVX offset to 0. I have run 45mins of AIDA64 and 1 hour of the latest Realbench without issues. Very pleased. I would still like to understand some of these settings better though, if anyone has the time to help me out.
07-06-2018 09:42 AM
Rozov wrote:
Where did you changed avx offset?
I've made an experiment with LLc it occures that when it's set on auto it doesn't drop corevoltage at load (tho it still randomly spike to about +0.016 (1.344) so I've turned llc to 7 (which is highest on my mobo) to see if that's what sets my chip on to this behavior and you know what it's dropping voltage from 1.328 to 1.312 at load and it also frickin spikes to same 1.344 wtf?! same's with llc6.
So what's the point using it at all if it's dropping even on max sett and also spikes, though when it's on auto it's not droping but spiking to the same value. Also i figured that if i downvolt a bit to 1.320 it will spike to 1.328 so that's 0.008 against 0.016, so the higher the voltage and these spikes grows exponentially.
What am I missing here?
I'll try to lower llc to 5 and see if the spikes will occure again, but man i don't want vdrop to much
07-06-2018 08:21 PM
07-07-2018 07:20 AM
Zammin wrote:
I'm not sure if your motherboard has AVX offset but you can see it in my first bios screenshot. Normally it is on Auto or 0 by default.
LLC7 is quite high and you may be at risk of severe overshoot, but as I mentioned in the original post I don't fully understand how to determine this since these overshoots can't be detected by software. I remember reading in an older post by Raja where he generally recommends LLC4 and LLC5 for daily use. I believe Der8auer also mentions LLC5 being safer than LLC6 for daily use as well in his 8700k overclocking guide video.
When I leave LLC on auto I get very severe Vdroop at these higher voltages, I find that under 1.30V LLC4 seems to keep vdroop in check and above 1.30V LLC5 seems to do the trick. I usually aim for around a 0.020v-0.040V vdroop during stress tests as I find this to be the most stable, however as I previously mentioned I don't know why this is as I don't fully understand LLC. I found this simply through trail and error. For example My first overclock on this chip was 4.8Ghz @ 1.275V manual voltage override and LLC6 which held the voltage at the set amount during stress tests (no vdroop detected in software), anything under this voltage would crash. However when I set up adaptive voltage I tried LLC4 at the same voltage which brought the voltage down to 1.232V under full load and it was totally stable.
It seems very strange that you are seeing vdroop on the highest LLC setting when that normally results in overshoot, but having said that we are on different CPUs and Chipsets so I can't be too sure. You're probably better off starting your own thread as you'll be more likely to get direct responses there.
07-08-2018 04:14 PM
