Lan issues
dnoam
Hi
i haveunusuall LAN issue . GettingINTERNETt connection running ( i havestreamingg data programs) but the LAN icon is probing and cannot upload Explorer or other programs , even Skype icon is not turning green , like i have to separate connections on 1 computer, i have another computer running on the same router ( not with Rampage 4) and all is ok . My question is if anything on that Rampage 4 cancreatet such a problem?It seems that in no windows forum somebody have that kind of a problem so i am posting the question here.
THANK YOU.
dnoam
Problem solved , i disabled Asus Fan service and all is fine , i have no idea what it does.
Retired
Not applicable
Sent from above..
Thanks..
I did a fresh install yesterday, and had the same issue..
I changed from auto to manual , and now the lan is working normal again
thanks
