Keyboard and Mouse General Hardware Help
Xysaerv
Im having issues with my laptop and hoping someone can help. I want to disable the magnifying feature on the mouse touchpad.
In addition I notice the left and right buttons arent very responsive. Is there away, I can increase there sensitivity?
Model Brand ASUS Series ROG G751 Series Model G751JY-DH71
General Color Black Operating System Windows 8.1 64-Bit CPU Type Intel Core i7-4710HQ 2.50 GHz Screen 17.3" Full HD Memory Size 24GB DDR3 Hard Disk 1 TB HDD + 256 GB SSD (2x128G RAID) Optical Drive Blu-ray-enabled DVD±RW/CD-RW Graphics Card Nvidia GeForce GTX 980M Video Memory 4GB Communication WLAN Battery Life Up to 3.5 hour(s)
CPU CPU Type Intel Core i7 CPU Speed 4710HQ (2.50GHz) Number of Cores Quad-core Processor CPU L3 Cache 6MB
Display Screen Size 17.3" Touchscreen No Wide Screen Support Yes Display Type Full HD Resolution 1920 x 1080
Operating Systems Operating System Windows 8.1 64-Bit
Graphics GPU/VPU NVIDIA GeForce GTX 980M Video Memory Dedicated 4GB Graphic Type Dedicated Card
Hard Drive SSD 256GB HDD 1TB HDD Spec 256 GB (2 x 128 GB RAID) + 1 TB HDD
Memory Memory 24GB
Optical Drive Optical Drive Type BD Combo Optical Drive Spec Blu-ray-enabled DVD+-RW/CD-RW
Communications WLAN 802.11a/g/n Wireless LAN Bluetooth Bluetooth 4.0
Supplemental Drive Webcam 1.2 MP HD Camera
Xenocrates
it may be that there is an application called "smart gesture", which i've found to cause the issue, and while it might be useful for some people, i find it to be utter junk. I'd try killing that, and taking it out of your run on startup applications. That's on my laptop, which while an ASUS product, is not a ROG laptop. it may show up in the taskbar/icon tray or whatever the hell you call it. That's the first thing i can think of, and a quick fix if it's the cause.
Thanks that helped a ton!
