Issue with my PC
Rabbitrider1
I've currently been having issues with my computer. It will shut off and try to boot back up and shut off again. When this happens I just shut the PSU off so it will stop. I get a message saying overclocking has failed, but I didnt have an overclock. So I came here asking for help and I got some. The problem was my RAM wasnt getting the 1.65v it needed since I have 2400 mhz. This worked for a couple of days, but then it shut off and trying to boot again to no avail. Someone was saying that I need to have my CPU overclocked to a minimum of 4.2ghz with 2400 mhz RAM. So after awhile I was able to get into the BIOS and overclock it to 4.4 ghz, but 15 minutes later I had the same issue repeat of "overclocking failed". Then I searched again online to see if I could troubleshoot the problem. I read that someone just had to update their BIOS and everything started to work again. So I updated my BIOS to 2801, and my computer worked for a day, but the problem is back now. Im just wondering if there is any last thing I can try before I RMA any parts to try and fix this problem.
I have a 4790k, Maximus VII Hero Motherboard, and 16gb of 2400 mhz RAM.
Also, could the PSU be causing this issue?
55 REPLIES 55
Nate152
No I don't think it's the ram, it's most likely the cpu's integrated memory controller or possibly the settings XMP is applying.
Try setting it manually with the settings I listed above and the cpu system agent voltage at 1.10v. The cpu system agent voltage helps stabilize the cpu's memory controller with high speed ram.
Yep and everything was pretty much setup by itself. all I had to change was the DRAM frequency and DRAM voltage
Ok thanks a bunch again.
Rabbitrider1
I tried setting the cpu system agent voltage to 1.10v but it wouldnt let me. It caps it at .999
Nate152
Rabbitrider1
Well it seems to be stable right now. Ill check again tomorrow and see if the problem comes back up. If you dont mind could I message you for help if I need it. You are pretty much the only person giving me any straight forward answers right now.
Thanks again for the help.
Nate152
You're welcome
If it is stable that's a good thing, run it for a while and see how it goes. In the meantime I will look up how to set the cpu system agent voltage if still needed.
Well after 2 hours of using my computer and it shut off again
Nate152
I just switched them into the black ones and it fired right back up first try. Normally that doesnt happen right after it shuts off.
