Great, thanks for the reply, that is just what i was looking for (and what i assumed to be true).
(EDIT: SEE BELOW EDIT2 FOR THE SOLUTION TO DRAM VOLTAGE THIS PROBLEM / FIX)
however can anyone shed any light on why it seems my DRAM voltage is *not* increasing despite what i manually set the voltage to. (ie at AUTO setting the voltage monitor in my BIOS shows the exact same DRAM voltage as when i set both DRAM voltages to 1.60)
please see screen shots of my bios:
(also note, when i ran memtest86 w memory at 1600mhz 8-8-8-24-2 (voltage to AUTO) i immediately started getting errors, when i changed the DRAM voltage to 1.60v (and left memory at 1600mhz 8-8-8-24-2) i still immediately got errors in memtest86 (ie it doesnt seem that the voltage is changing, even though i expected errors at 1.60v i thought the errors would come slower or take a bit more testing to get errors, but they appeared just as fast as at AUTO 1.50v DRAM voltage)
(note i did reboot after setting the DRAM voltage to 1.60v)
my memory is: 32GB GSKILL RIPJAW F3-1600C9Q-32GXM (this exact memory is on my MB's ASUS QVL list)
My MB is: Asus RIVbe (bios 701 , the latest except for the beta 801 BIOS which just addresses some issue that doesnt affect me)
EDIT: I even just now took out my multi-meter and tested the DRAM AB Voltage point (duhh, why didnt i do this before) - but during memtest86 testing DRAM AB point showed 1.445v and DRAM CD point showed: 1.439v (with BIOS DRAM AB and CD both still set to 1.60v)
EDIT 2 : I CAN ANSWER MY OWN QUESTION (RE voltage not taking): it seems that when you change the "RAMPAGE TWEAK" setting TO MODE 3, it will override or cap the max DRAM Voltage you can set. I had it set to MODE 3 (which the help text says is best for IVY-BRIDGE CPUs, which i have) -- ONCE i set this BACK TO AUTO (or im assuming MODE 1 or 2 just NOT mode 3) the DRAM VOLTAGE changed to exactly what i manually set. (incase others have this same issue)
