03-09-2018 04:42 PM - last edited on 03-06-2024 09:03 PM by ROGBot
03-18-2018 07:35 PM
03-19-2018 12:02 AM
04-02-2018 01:40 AM
04-02-2018 02:45 AM
04-02-2018 03:14 AM
Menthol wrote:
Any AIO is borderline for a 7980XE but the larger radiator the better, 360 will only be slightly better than a 280, is the AIO new or used if used how old as the pumps get weaker as they get older, best AIO is probably EK
1.35 volts is way to much for an AIO and more than should be needed for that clock and probably why it is rebooting - pulling to much current causing high heat and motherboard over current, or over heating protection circuit kicking in to protect CPU and motherboard from damage
Test first with memory at default (auto), no XMP, enabling XMP may change bios settings that you don't see, first get CPU stable then memory
4.2 ghz @ 1.087 to 1.100 volts max, AVX offset -3 AVX 512 offset -5, cpu input @ 1.8 volts, LLC 5 or 6, svid - auto
04-02-2018 03:23 AM
04-02-2018 03:36 AM
