09-02-2018 03:24 AM - last edited 3 weeks ago by ROGBot
09-03-2018 02:26 AM
09-09-2018 09:17 AM
georgeclintonfan wrote:
Haswell (haswell refresh) processors have integrated VR , so it's common for cpu package temperature to exceed cpu core temperatures, because package temp is the whole chip which includes integrated VR. I've found that the temperature of VRM usualy hoover around 50C, so if your cores are at 30's then 40 is reasonable for cpu package temp.
09-11-2018 12:06 PM
cyber_flame wrote:
Just fixed this by Enable CStates Pacakge to C7s. Now its down.
09-26-2018 01:34 AM
Owneth wrote:
I would mess with the input voltages. I had stability issues also with mine but part of that was a bios upgrade.
I did my min and max input voltage to 1.85v and 1.91v (eventual). Helped a ton with stability and temps.
Also there is a trick for long duration power limit etc which affects only boosting the cache cores. I'd suggest finding a good medium that works for you.
Delidded 4790K and a Maximus Hero VII board with 3503 bios , liquid metal TIM and its down to 65-68c temps, 68 on hottest core. Aidax64 in a 24 hour run.
4.8ghz and 4.6ghz cache @ 1.346v.
09-26-2018 03:06 AM
09-26-2018 04:58 AM
ThrashZone wrote:
Yeah cpu package can be 4c-8c hotter
C-states never made a difference I've ever noticed.
If you look at hwinfo it will show two cpu package temps I usually go by the highest.
There is also cpu (PECI) lol just to throw another one in the vcore temp loop but probably the most accurate :cool:
